Latest: Puggingalong
Overall: 17129
Online Now [429]:
Visitors: 428
Today: 35625
Total: 100704987
Forums › The Car › 206 Problems › Peugeot 206 Horn
Peugeot 206 Horn
Janetsman
PostPosted: Thu Jul 05, 2012 1:36 pm Up
Can anybody help please. My horn as suddenly started working only
intermitantly . Can anybody give me a clue where to start looking. Could it be a fuse?
muxloemax Turbo
PostPosted: Thu Jul 05, 2012 1:37 pm Up
Normally rotten wires on the horn connector plug.
PostPosted: Thu Jul 05, 2012 1:51 pm Up
Remove the horn and manually test if it's working, then if it is test if voltage is getting to the plug.
If no to both then check wiring / fuses
Janetsman
PostPosted: Thu Jul 05, 2012 2:05 pm Up
Is this plug coming off the horn unit underneath the front bumper. If so
is it best replacing with a new horn unit.
muxloemax Turbo
Janetsman
PostPosted: Thu Jul 05, 2012 2:13 pm Up
just got your reply thanks i will try what you said also thanks to Mr BSI for your help.
Regards
Janetsman
muxloemax Turbo
PostPosted: Thu Jul 05, 2012 3:07 pm Up
IF the plug is at fault then its normally the horn wiring on the car that needs repair / replacing.
Peugeot sell a loom repair section for the horn OR go down the scrapyard & get a good one of another 206 then solder & heatshrink it on to your car.
PostPosted: Thu Jul 05, 2012 3:13 pm Up
I worked on one once where it was a bad connection in the plug, a good clean with some electrical cleaner and it was all working again.
Best to take a look and go from there, the horn circuit is very simple.
