Online Now [1128]:
Visitors: 1128
Today: 162815
Total: 155253889
Forums › The Car › Request a how-to › How to change the rear fog light bulbs?
very_452001
PostPosted: Thu Jul 05, 2012 4:18 pm Reply with quote Up
How many rear fog lights are there and what bulbs they take?
cheers,
very_452001
QuArTz
PostPosted: Thu Jul 05, 2012 5:05 pm Reply with quote Up
Trade Rating: +16
There's only one fog light..
The rear fog light can be removed in the same way the indicators are removed.
Push the fog lamp to one side, i think its the left, that will release the clip then allow it to come towards you.
Once out, twist the grey plug and release it from the fog lamp and then you can change the bulb.
The bulb is the same as THIS
very_452001
PostPosted: Thu Jul 05, 2012 5:14 pm Reply with quote Up
in the rear fog light on the drivers side?
i open the boot to access the back of the rear light and I can see fabric boot trim blocking my way. How do i remove this trim?
very_452001
Matt
PostPosted: Thu Jul 05, 2012 5:35 pm Reply with quote Up
Trade Rating: +32
The fog light is not in the rear cluster. It's in the middle of the rear bumper.
Matt
PostPosted: Thu Jul 05, 2012 5:38 pm Reply with quote Up
Trade Rating: +32
You need to lay on the floor and stick your head under the rear of the car. You will see the wiring with the grey plug. If you twist the plug it will come out with the bulb holder. Swap the bulb over then do the reverse to replace it.
hayes_ctfc
PostPosted: Fri Jul 06, 2012 3:39 am Reply with quote Up
You don't even need to touch the boot, let alone unlock the car to do it, Matt has described it fully
OLD: Peugeot 206 2.0 GTi 138
NEW: Seat Leon FR TDi 170
very_452001
PostPosted: Fri Jul 06, 2012 3:53 am Reply with quote Up
Thanks got it.
very_452001
very_452001
PostPosted: Sat Jul 14, 2012 3:58 am Reply with quote Up
Update: I put a new bulb in and its still isn't working. I checked the connection in the bulb holder and its rusted/dirty. What's the best way to clean it?
very_452001
anton1989
PostPosted: Sat Jul 14, 2012 6:02 am Reply with quote Up
Trade Rating: +16
this may sound silly but you do know the rear fog has a seperate switch dont you? it does'not come on with the front ones. i had to show someone this before.
if you already know that then only thing i can think is fuse?
very_452001
PostPosted: Sat Jul 14, 2012 6:33 am Reply with quote Up
i know how to turn the rear fog light Razz
i check the fuse.
very_452001
PostPosted: Sat Jul 14, 2012 7:59 am Reply with quote Up
Have you checked the fuse with a multimeter or by eye?
Have you put a multimeter across he contacts of the bulb holder to make sure 12v is getting to it?
very_452001
PostPosted: Sun Jul 15, 2012 5:53 pm Reply with quote Up
which fuse is it for the rear fog lights?
Its multiplexed
very_452001
PostPosted: Mon Jul 16, 2012 2:00 am Reply with quote Up
Its multiplexed
The answer is on this site somewhere, but like you I can't be bothered to search for it.
You can have this one for free, open the bonnet and think of a number between 5 and 7. It should be the colour of the films you keep hidden under your bed.
very_452001
PostPosted: Mon Jul 16, 2012 4:10 am Reply with quote Up
macca1411 wrote:
Its multiplexed
Forgive me as I'm new to the site Very Happy , yeah I checked out the fuse link on this site and there are 3 layouts? I'm confused as I belive there should be 2 fuse boxes right?
very_452001
PostPosted: Mon Jul 16, 2012 4:31 am Reply with quote Up
You're spot on. 2 Fuse boxes. 1 in the car under the steering column and one under the bonnet.
You should have got a link to this sent to your inbox when you joined the site. It's worth having a read as there is a lot of information that you are going to need to know, including a useful fuse list.
You may be new to the site, but you are asking very basic questions which make me think you are new to cars. By messing with the electrics when you know nothing about them you risk doing more damage. If in doubt, pay someone to do the job for you. It will work out cheaper in the long run.
  Quick Reply
Username:
Message:
Quote the last message
