Latest: flipflap
Overall: 17140
Online Now [107]:
Visitors: 106
Today: 31439
Total: 113736452
Forums › The Car › 206 Problems › 206 hdi clutch/gearbox issues
andymc872
PostPosted: Sun Jul 08, 2012 9:22 am Up
hi there im now to the site,
i have a 206 2.0 hdi 2001, i have a rattle/knock when my car is idleing and also driving in up to around 2000 rpm, its seams to be from the gearbox area, the noise slightly changes pitch when the clutch is pressed but only slight, i have drained the gearbox oil and put new oil in (correct spec) and the old oil didnt have any pieces of metal ect in it as id have thought.
i am really stumped here as noise is always there no matter clutch position,
my clutch also bite very near the top if this has any significance.
i have read it could be input bearing, release bearing or pressure plates does anyone have a suggestion many thanks
andy
Andy 2001 206 hdi 2.0
PostPosted: Sun Jul 08, 2012 9:24 am Up
it will never have metal piece in the gear oil as there is a magnet inside the gearbox to trap the metal piece
andymc872
PostPosted: Sun Jul 08, 2012 9:27 am Up
ok thanks, do you have any suggestion to what it could be?
PostPosted: Sun Jul 08, 2012 9:30 am Up
I get the feeling this will end up with needing a new clutch kit being fitted sooner rather then later.
andymc872
PostPosted: Sun Jul 08, 2012 9:45 am Up
thanks ill whip the box off this week and look
