Latest: ArtistKS
Overall: 17145
Online Now [53]:
Visitors: 52
Today: 13463
Total: 115954385
Forums › The Car › 206 Problems › strut bearing
strut bearing
robclowes
PostPosted: Sun Jul 08, 2012 10:29 am Up
How difficult is it to replace a strut bearing, front off side? Is there a how to?
206 1.6 xsi
ukskater01
PostPosted: Sun Jul 08, 2012 10:39 am Up
I think you need spring compressors so not that easy, gonna get mine replaced when my new rear axle is fitted as they have been making noise for ages
SinfulDesignCom
PostPosted: Sun Jul 08, 2012 10:50 am Up
if you've not done it before its a pain in the ar*e. If you are likely to be replacing more parts, thus repeating the job, I suggest you learn and save yourself a load of moola
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
You need to remove the strut from the car for a start.
PostPosted: Sun Jul 08, 2012 4:36 pm Up
Pain in the a**e! Not hard but quite a few bits to disturb / remove and always a bugger reconnecting that lower wishbone.
Also very dangerous if you aren't used to using spring compressors.
Buy yourself a Haynes manual. It isn't the answer to everything but it always gives a clear idea of just how easy or hard a job is. Use the manual but ask what special tips others know here.
