Latest: dreyfalon
Overall: 17121
Online Now [573]:
Visitors: 572
Today: 36291
Total: 97562613
Forums › The Car › 206 Problems › Speedometer Accuracy
Go to page Previous  1, 2
PostPosted: Sun Jul 08, 2012 5:16 pm Up
20% suggests you have a much bigger problem. While the calculators are not spot on thta is due to manufacturers slight differences NOT the calculator as the maths is simple.
196 / 65 / 14 tyre has the following diameter:-
Convert 14 inches to mm = 25.4 x 14 = 355.6mm
195 / 65 tyre has a wall hieght of 195 x 0.65 = 126.75mm
there are two lots of wall hieght in the overall diameter so the overall tyre / wheel combo diameter is:-
355.6 + 126.75 +126.75 = 609.1 mm
The following site shows the same:-
www.tyresave.co.uk/tyresize.html
And this one shows speedo reading changes
www.miata.net/garage/tirecalc.html
The calculator results may not be spot on but they are within a few %. If you are 20% out then either you are using the calculators incorrectly or you have another problem.
NOTE: most speedos overread by between 5 and 10% (indicated 30 = real 27) so any change the calculator gives needs to factored onto the original innacuracy. 20% still suggests another problem though!
Page 2 of 2
