Posted: Wed Jul 11, 2012 4:36 pm |
as per the title is there any tip on removal is it a drill and tap job
| If your offended by my posts call\r\n0800 I dont care | |
Posted: Wed Jul 11, 2012 4:50 pm |
Just chisel it to make a big wide slit in the end, then use a big flat head ect to turn it out or just drill and tap it out the thread will come out once the heads off I found.
Posted: Wed Jul 11, 2012 5:29 pm |
I may give it a shot it seems as though the last owner lowered the rear and over tightened the torsion bar bolts or used a whizzy gun bloody fools
Posted: Wed Jul 11, 2012 6:24 pm |
That works well actually! Use heat as well if you can
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
Posted: Thu Jul 12, 2012 8:36 am |
Chisel + hammer and patience usually works well
Posted: Thu Jul 12, 2012 3:14 pm |
I used a woodworking chisel to actually cut into the head and another knock and it came loose.
