Latest: DanDan17
Overall: 17128
Online Now [106]:
Visitors: 105
Today: 7076
Total: 100481913
Forums › The Car › 206 Problems › Heater vents
Heater vents
DanT
PostPosted: Thu Jul 12, 2012 4:59 pm Up
Hi, got a slight issue with my drivers side heater vent, when i bought the car it had a cheapy phone holder stuck into it, which seems to have slightly damaged the directional mechanism part. I'm wondering is the inner vent part itself removable or do i have to replace the whole thing, ie the surround etc. As my car is a Gti 180 it has different surround etc and wanted to know if i could just get the inner vent part from any model 206?
Thanks a lot. Dan.
Matt
PostPosted: Thu Jul 12, 2012 7:07 pm Up
Trade Rating: +32
The directional part is a rubber "band" that holds onto small pins on the rear of each vertical blade. My guess is that one of the pins has snapped off. It would probs be best and easiest to just change the whole vent. It will only cost you £3-4 from the scrappy.
PostPosted: Fri Jul 13, 2012 1:09 am Up
you can replace the inner part and keep the outter surround Smile
DanT
PostPosted: Fri Jul 13, 2012 2:07 am Up
Thanks this is the information i wanted to hear! Smile
DanT
PostPosted: Fri Jul 13, 2012 2:09 am Up
Cheers i figured it was that sort of set up but just wanted to check before i go and remove one from a car. As long as i can change the vent itself and keep the surround i'm happy! Smile
Matt
PostPosted: Fri Jul 13, 2012 2:32 am Up
Trade Rating: +32
Yea the vent "pod" pops out. That is the part I meant when I said will be easier to just swap the vent, not the surround.
