Latest: kemppu
Overall: 17142
Online Now [112]:
Visitors: 111
Today: 13556
Total: 114052838
Forums › The Car › 206 Talk › Which valve spring compression tool for TU3?
PostPosted: Sat Jul 14, 2012 5:48 am Up
Thinking of overhauling cylinder head myself sometime in autum.
Trying to think ahead and prepare a bit, which of the tools available works best with the TU3 setup
because there are many types of valve spring compressors?
Anyone know?
Cheers.
PostPosted: Sat Jul 14, 2012 1:29 pm Up
I don't recommend that you do that by yourself,this kind of work needs a mechanic so that he do it right from the first time,that will cost you less.
PostPosted: Sat Jul 14, 2012 2:50 pm Up
Thanks for advice Timon. I would agree but I'm pretty confident and have all the rest of the tools needed.
I have also relapped valves before a couple of times on smaller engines.
Anyone else?
PostPosted: Sat Jul 14, 2012 4:58 pm Up
Anyone else?
www.lasertools.co.uk/i...p;item=123
frd of mine use this to rebuild his 106 XSI
PostPosted: Sun Jul 15, 2012 2:30 am Up
Yes that looks correct for TU3.
Thanks.
PostPosted: Sun Jul 15, 2012 10:17 am Up
A generic valve compressor does the job, there is no actual specific one as far as im aware
And rebuilding a cylinder head aint brain surgery tbh, weekend job if that really
