Posted: Sat Jul 14, 2012 3:19 pm |
Trade Rating: +16
well as if i never had enough problems with my last car
bought myself a hdi today 2ltr, black, 3dr, 52plate, 97,000 miles, AND some problems
so everything was fine on the test drive car was spot on, clutch good, gearbox good etc etc. was very dirty and need the odd thing like a fog light as the old one had water in? and some other stuff. for the price not really bothered.
on to the issue im new to the multi-plex model before i go further, on the drive home i stopped for diesel and noticed the aftermarket h/u stayed on alond with the mfd, thought yellow red wire issue, also noticed the indicators did not flash when i locked the car? so got home and started to pull the h/u out. it kept getting caught on something so removed the whole vent/mfd display thing to find that the mfd display had been hot wired to the h/u live???????
so took the display thing off and wires had been cut and a wire went down to the live feed ment for the h/u
so took this off, re-wired the mfd, connected the battery back up and started the car to see . . . . . . . . . . . . . . . . . . . . . . AIRBAG FAULT and ANTI-POLLUTION FAULT
why me???????????
guy says has no idea and never knew
what is the anti-pollution fault?
horn not working so could this be the spool thing causing airbag fault?
Posted: Sat Jul 14, 2012 3:23 pm |
Maybe it has been wired to HU to prevent buyers from seeing it has an anti pollution fault.
Anti pollution fault is usually a problem with the cat;emissions. Could be a exhaust leak, bad injector, EGR fault.. Best way to find out is to have is to have it plugged in and have the fault read, and then go from there with the code.
| Project Low and Slow.. Going Euro for 2013. Keep your eyes peeled, big plans ahead..
See my project here. | |
Posted: Sat Jul 14, 2012 3:28 pm |
Trade Rating: +16
anyone in the midland that read faults for a fellow 206info member?
Posted: Sat Jul 14, 2012 3:31 pm |
Where abouts in the midlands are you?
Posted: Sat Jul 14, 2012 3:32 pm |
Trade Rating: +16
2Oh!6 wrote: |
Where abouts in the midlands are you? |
nuneaton but can travel
Posted: Sat Jul 14, 2012 3:42 pm |
Not having much luck are you!
My Dad has a fault reader but wouldn't be worth you travelling really, not having much luck with the hdis are you! How much did it set you back?
Posted: Sat Jul 14, 2012 3:46 pm |
Trade Rating: +16
tomd0801754 wrote: |
:rofl: Not having much luck are you! |
Posted: Sat Jul 14, 2012 3:48 pm |
Trade Rating: +16
2Oh!6 wrote: |
My Dad has a fault reader but wouldn't be worth you travelling really, not having much luck with the hdis are you! How much did it set you back? |
nope £1300 not bad depending on these faults? drives very well
been told diesel particulate filter system is due for servicing or somthing?
Posted: Sat Jul 14, 2012 3:53 pm |
there wasn't one on the 2.0
1300 is a bit too much with those fault...
Posted: Sat Jul 14, 2012 3:55 pm |
should of bought Poppy from Tom
| Ford Focus RS in white of course
filled with all sorts of goodies | |
Posted: Sat Jul 14, 2012 3:57 pm |
Trade Rating: +16
Seabook wrote: |
1300 is a bit too much with those fault... |
got it down from 1420 aswell lol.
nevermind stuck with it now, so will have to see what the problems are
Posted: Sat Jul 14, 2012 3:59 pm |
Trade Rating: +16
marc206 wrote: |
should of bought Poppy from Tom |
and have my wheel fall off
ill stick with the airbag fault thanks
Posted: Sat Jul 14, 2012 4:01 pm |
anton1989 wrote: |
marc206 wrote: |
ill stick with the airbag fault thanks |
Posted: Sat Jul 14, 2012 4:04 pm |
Trade Rating: +16
the joke is this car was my second choice! i found one on autotrader had my heart set on already making plans on the way there, got there and the d**khead had sold it wtf i rang before i left aswell
