Latest: heikkisj
Overall: 17126
Online Now [101]:
Visitors: 100
Today: 22593
Total: 100258877
Forums › The Car › 206 Talk › Gti 180 cam cover gaskets?
DanT
PostPosted: Sun Jul 15, 2012 8:06 am Up
Just a quick one! Do these use a gasket for each cover or is it just sealant? One of mine seems to be weeping slightly towards the corner Sad , just want to know so i can grab one tomorrow or just use the sealant i've already got. Thanks in advance! Smile
SinfulDesignCom
PostPosted: Sun Jul 15, 2012 8:52 am Up
gasket for each one. would avoid sealant if you stretch to the part - just go careful when fitting and follow the recommended torque settings
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
DanT
PostPosted: Sun Jul 15, 2012 9:17 am Up
Cool i thought it would be a gasket just wanted to check. Yeah fitting it is no problem, thanks a lot! Smile
PostPosted: Sun Jul 15, 2012 10:15 am Up
Which cover? As the the 138 uses a simple gasket for the upper and sealer for the lower
Ps forget the torque settings, they are sweet fa anyway
Just make sure you go in an outward spiral Wink
usher
PostPosted: Sun Jul 15, 2012 12:14 pm Up
think the gti and 180 are the same
got mine from uni[art for think 12quid each one was labeled for a merc lol
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
DanT
PostPosted: Sun Jul 15, 2012 4:56 pm Up
Its the upper one. I've no idea about the 138 but this looks as though it does have some sort of rubber gasket. Will sort one out tomorrow any way and report back!
DanT
PostPosted: Mon Jul 16, 2012 4:39 pm Up
Just to update this, got and fitted both today, rubber gaskets as expected. Got both for about £15 quid so all is good now!
SinfulDesignCom
PostPosted: Mon Jul 16, 2012 6:43 pm Up
Right - lets all torque our cam cover gaskets to 50Nm.... Very Happy
