Posted: Mon Jul 16, 2012 3:41 pm |
Trade Rating: +16
I need to replace the front discs and pads on my 54 plate 1.4 petrol.
Could someone tell me the correct dimensions of the discs and pads I would need for my car.
I dont really want to buy new pads and discs, get them home, get all the bits ready, only to find out I have bought the wrong ones.
On a lot of websites im being given multiple choices and I would like to get the correct ones first time.
Thank you
Posted: Mon Jul 16, 2012 3:53 pm |
QuArTz wrote: |
Not without the VIN number.
Posted: Mon Jul 16, 2012 3:55 pm |
Should imagine you'll have ABS so will be Ø247x20.4mm
Posted: Mon Jul 16, 2012 3:57 pm |
Trade Rating: +16
Yes... I does have abs.
When pushing the caliper back to fit new pads I should undo the bleed nipples so not to damage the the abs pump.
Is that correct?
Lee wrote: |
Should imagine you'll have ABS so will be Ø247x20.4mm |
Mine where 247mm x 13mm with ABS, EBD & EBA
Posted: Mon Jul 16, 2012 4:00 pm |
QuArTz according to Peugeot Service Box your car left the factory with the 247mm x 13mm solid front disc brake set up.
If your thinking of a GTI front brake upgrade now would be the time to do it, calipers bolts straight on
Posted: Mon Jul 16, 2012 4:13 pm |
Surely ABS should run vented discs? A bit s**te running solid
Posted: Mon Jul 16, 2012 4:16 pm |
MrBSI wrote: |
If your thinking of a GTI front brake upgrade now would be the time to do it, calipers bolts straight on |
I have gti callipers with mintex pads and discs that have only done 1000 miles for sale
Lee wrote: |
Surely ABS should run vented discs? A bit s**te running solid |
It stopped fine with the solid discs on, just didnt like repeated stopping as they faded pretty easily
Mine stops just the same with the 266mm x 22mm vented front discs, they dont seem to mind repeated stopping
Posted: Mon Jul 16, 2012 4:17 pm |
I'm heavy on brakes so need vented
Posted: Mon Jul 16, 2012 4:19 pm |
Lee wrote: |
I'm heavy on brakes so need vented |
Same here
Posted: Mon Jul 16, 2012 4:45 pm |
Trade Rating: +16
LeeThr wrote: |
MrBSI wrote: |
I have gti callipers with mintex pads and discs that have only done 1000 miles for sale |
How much do you want for the calipers, pads and discs posted?
Posted: Mon Jul 16, 2012 4:56 pm |
QuArTz wrote: |
LeeThr wrote: |
MrBSI wrote: |
How much do you want for the calipers, pads and discs posted? |
£55 all in posted. Cost me just a bit more than that for just the discs and pads.
Posted: Mon Jul 16, 2012 5:02 pm |
QuArTz wrote: |
lol i does
Posted: Mon Jul 16, 2012 5:05 pm |
Trade Rating: +16
MrBSI wrote: |
Thanks for the info MrBsi, very much appreciated
