Latest: Andyblue64
Overall: 17123
Online Now [65]:
Visitors: 64
Today: 55658
Total: 98327236
Forums › The Car › 206 Problems › 1.6 XSI Sump
1.6 XSI Sump
Neil206
PostPosted: Tue Jul 17, 2012 4:41 am Up
bought a new plug and seal from peugoet, come to tighten it up, and it tightens upto tight (maybe a tad tighter than tough tigh - if that makes any sense haha) but if tightened any more will become loose again
and i dont want to be driving along and have the plug become loose,
isit normal for the plug to be like this? if the above makes any sense at all
cheers in advance, neil
206
PostPosted: Tue Jul 17, 2012 4:42 am Up
Sounds like a stripped thread OR incorrect sump plug.
What was the old sump plug like to remove? Does that tighten up ok?
Neil206
PostPosted: Tue Jul 17, 2012 5:12 am Up
the same, they both behave the same, i presume its MENT togo very tight and then no further?
206
PostPosted: Tue Jul 17, 2012 5:20 am Up
you will need to rethread the sump then.
it suppose to hold tight. screw driver is more then enough to tighten the sump plug.
PostPosted: Tue Jul 17, 2012 5:25 am Up
Sounds like the thread is stripped in the sump then.
You might be able to get a helicoil repair done on it BUT its a job for an expert / someone that knows what there doing!
Other then that its a new sump.
PostPosted: Tue Jul 17, 2012 5:40 am Up
helicoil is easy to use Laughing
but ithough you need to take the sump off the car first? Question
PostPosted: Tue Jul 17, 2012 5:44 am Up
Only for some people Wink
PostPosted: Sun Jul 22, 2012 10:47 am Up
Sump repair. it can be done in situ (few will though) and it won't be cheap. Don't drive it like it is - well maybe to the garage and then watch the oil light very closely and stop immediately if the pressure drops or light comes on
Neil206
PostPosted: Sun Jul 22, 2012 11:21 am Up
rough estimated price on gettign a new sump & gasket fitted at a garage?
cheers in advance
found sumps at £30 delivered, + £10 for a new gasket
206
PostPosted: Sun Jul 22, 2012 11:25 am Up
Why not do it yourself?
Big_Rich180
You need to call the garage that you will have the work done at.
It doesn't matter what anyone says on here unless they are doing the job.
PostPosted: Sun Jul 22, 2012 11:26 am Up
Helps if we knew what engine it is Rolling Eyes
Neil206
PostPosted: Sun Jul 22, 2012 11:32 am Up
sorry the 1.6 xsi (tu5jp4??) I could do it myself but i have a lot on at the moment
206
PostPosted: Sun Jul 22, 2012 11:37 am Up
Topics merged, there was no need for a seprate topic when you already have one open about the samething.
Neil206
PostPosted: Sun Jul 22, 2012 11:40 am Up
apologies
206
