Latest: DanDan17
Overall: 17128
Online Now [54]:
Visitors: 53
Today: 14568
Total: 100534507
Forums › The Car › 206 Problems › 206 GTI 180 Problems - wont start!
Go to page Previous  1, 2, 3
PostPosted: Tue Jul 17, 2012 3:41 pm Up
If the ECU is locked then there is a immo fault/short circuit.
If it's unlocked, then your problem lies elsewhere.
Have you checked multifunction relays?
chris_87
PostPosted: Tue Jul 17, 2012 3:51 pm Up
Ok makes sense - does the immobiliser cut anything other than fuel though? So far I Don't think it looks like an immobiliser problem as I've been able to read error codes etc..
Multifunction relays - haven't checked any of those - any idea which ones I should be looking at?
PostPosted: Tue Jul 17, 2012 3:52 pm Up
Its a total software lock on the engine ecu to stop the engine running.
chris_87
PostPosted: Tue Jul 17, 2012 3:57 pm Up
Ok that's good - it won't be immobiliser then, all I've done at the moment is put a wire from power source to fuel fump and the car runs perfectly - took it for a 5 min drive and it was fine...
So I'm guessing that leaves us with wiring, fuses or relays?
Any ideas on the best place to start? Lol
Page 3 of 3
