Latest: DanDan17
Overall: 17128
Online Now [113]:
Visitors: 112
Today: 2361
Total: 100522327
Forums › The Car › 206 Problems › shows injector fault
anthony
PostPosted: Wed Jul 18, 2012 1:03 am Up
I have a pug 206 2001 1360cc it is misfiring on number 4 cylinder computer says injector fault fitted new on also changed the coil pack plugs checked the wiring and had the e c u checked out still misfiring computer still say injector fault any Ideas im out of them
mrpug
PostPosted: Wed Jul 18, 2012 1:27 am Up
did you change the correct one?
PostPosted: Wed Jul 18, 2012 2:43 am Up
Number 4 is the TIMING BELT end.
paul_c
PostPosted: Wed Jul 18, 2012 3:37 am Up
Are you sure?
Ash
PostPosted: Wed Jul 18, 2012 3:54 am Up
paul_c wrote:
Are you sure?
He used to work at Peugeot Dealers, he'll be sure.
paul_c
PostPosted: Wed Jul 18, 2012 4:28 am Up
No worries, the only reason I ask is that by convention, almost all inline engines have their cylinders numbered with 1 starting at the pulley (non flywheel) end. If its the case though, it certainly explains the original poster's issue!
PostPosted: Wed Jul 18, 2012 5:24 am Up
Peugeot like doing things backwards. Inj 1 is gearbox end.
PostPosted: Wed Jul 18, 2012 5:44 am Up
paul_c wrote:
Are you sure?
100% sure, that's why injector 4 always failed first because of the bonnet vent
PostPosted: Wed Jul 18, 2012 5:49 am Up
Seabook wrote:
paul_c wrote:
Are you sure?
Its NOT the bonnet vent Wink
Its the washer jet, rain water leaks behind the washer jet & drips straight down on to number 4 injector, thats why 206's with the under bonnet cover dont seem to suffer from injector failures.
PostPosted: Wed Jul 18, 2012 5:50 am Up
MrBSI wrote:
Seabook wrote:
paul_c wrote:
Are you sure?
ok, leaky windscreen pipe then Laughing
PostPosted: Wed Jul 18, 2012 5:52 am Up
paul_c wrote:
Are you sure?
100% sure, seen no end of people change the wrong injector on PSA stuff as they think that number 1 is timing belt end - NOT in PSA world its not Laughing
PostPosted: Wed Jul 18, 2012 5:59 am Up
I have never worked for Peugeot or Citroen.
I have had a Peugeot main dealer mechanic ask me how to fix a 306 alarm system before Laughing
PostPosted: Wed Jul 18, 2012 6:12 am Up
Jesus, was he the new monkey?
PostPosted: Wed Jul 18, 2012 10:17 am Up
Nope, they had run out of ideas Wink
Blown headlamp bulb was the problem Laughing
PostPosted: Wed Jul 18, 2012 10:35 am Up
How the hell did that mess about with the alarm?
