Latest: Andyblue64
Overall: 17123
Online Now [274]:
Visitors: 273
Today: 13703
Total: 98201999
Forums › The Car › 206 Talk › What part needed?
What part needed?
karimali831
PostPosted: Wed Jul 18, 2012 9:24 am Up
The gaiter on the arm has a very small split and apparently needs to be changed to pass MOT. Here in the picture you can see the gaiter that needs replacing and the smaller circle where the split is. Can't the split just be patched up to avoid the expensive hours labour to pull apart the arm? If not that can anyone tell me what the part is I tried searching for it on ebay.
Wish I had cleared the sludge under the gaiter that way they wouldn't of had to look at the split Sad
uploadpic.org/storage/...mOEQEi.jpg
206 GTI 180
Abzynthe
PostPosted: Wed Jul 18, 2012 9:26 am Up
East Area Rep - Abzynthe
Thats a CV boot, cheap enough Smile
Not sure if you can get it through the MOT by patching it up though. Im sure someone else will say if you can.
PostPosted: Wed Jul 18, 2012 9:40 am Up
Yep, CV boot, might as well just get it done, dont want to patch it up and loose all the grease, could end up snapping the CV joint.
PostPosted: Wed Jul 18, 2012 9:41 am Up
Do it properly first time around, wont need to be done again then.
cartoonhead
PostPosted: Wed Jul 18, 2012 9:58 am Up
inner CV boot rubber.
better off just changing it as other have said
PostPosted: Wed Jul 18, 2012 9:59 am Up
that's why some people has destroy their driveshaft
PostPosted: Wed Jul 18, 2012 10:02 am Up
Usually people who are trying to run a car they cant actually afford to run.
karimali831
PostPosted: Wed Jul 18, 2012 11:41 am Up
First quote £120, second quote £90 third quote £70! Very Happy
Will have to get this done to qualify for free MOT test within 7 day period.
Thanks all.
206 GTI 180
