Latest: sparrowdclxvi
Overall: 17139
Online Now [156]:
Visitors: 155
Today: 41964
Total: 112615302
Forums › The Car › 206 Problems › HELP NEEDED
HELP NEEDED
kingsway2468
PostPosted: Thu Jul 19, 2012 8:41 am Up
hi i have a 2006 1.6 206cc I was driving the other day and errors come up on the centre screen it brings up abs fault, airbag fault, braking fault and battery charging fault the car then cut out and wouldnt start, someone came and i put jump leads on the car and got the car goin but cut out a few more times on the way home so had to keep jump starting it. Anyway i got the car home after all that bother and people told me on here that faults come up if the battery is low so i have changed the fuse box, battery and alternator and still does the same and is really starting to p**s me off now so if any one has had this fault or knows what the problem is please could you let me know
thanks
PostPosted: Thu Jul 19, 2012 8:54 am Up
You really need to get the codes read and cleared, all so but jump starting you may have damaged the BSi as you are not suppose to jump start the 206 you would of been better to take the battery off and charging it.
kingsway2468
PostPosted: Thu Jul 19, 2012 9:20 am Up
i have had it read on a mates code reader but it didnt pick up anything or would it need to go to main dealers?
how much is BSi? and will one out of any car go in? and will it need coding?
d roth
kingsway2468
PostPosted: Thu Jul 19, 2012 10:43 am Up
as i changed alternator earlier i put the battery on charge for few hours just started up and took for a drive for about 30 minscar was fine as soon as turned lights on i had no throttle and cut out and battery was flat again
think im gonna have to get it checked by a auto electrician dreading the bill tho
d roth
