Latest: sparrowdclxvi
Overall: 17139
Online Now [340]:
Visitors: 339
Today: 26275
Total: 112599703
Forums › The Car › 206 Problems › Urgent Help - rear Light not working (drivers side)
Rich_T
PostPosted: Thu Jul 19, 2012 10:36 am Up
I nede some help my Frivers side rear light isnt working, but the bulb is OK, the dip light on the same side isnt working - again the bulb is OK ( the little tiny bulb in the light cluster) also the lights behind the heater controls have gone out.
Car is a 2001 206 and i need to use it later this evening with all lights working, and next week - i wont have access to anywhere that will be able to fix it Sad
PostPosted: Thu Jul 19, 2012 10:43 am Up
Fuse?
Rich_T
PostPosted: Thu Jul 19, 2012 11:07 am Up
checked the fuses, and the all seem OK Sad
mtempsch
PostPosted: Thu Jul 19, 2012 11:52 am Up
Check again - best with a multimeter, as they can be deceptive and look OK to the eye but still not conduct...
IIRC, rear light and front sidelight run off the same fuse (per side), so I'd say the fuse is still the primary suspect.
Heater panel lighting should be off the same feed as other gauges/buttons illumination; so if others work it's probably local to the panel (wire, blown bulbs etc)
Silvermetallic 2004 206 RC
Rich_T
PostPosted: Thu Jul 19, 2012 1:14 pm Up
All fuses checked with a multimeter, and all fuses OK.
also the brake light in teh same cluster is not working, although the indicators do.
mtempsch
PostPosted: Thu Jul 19, 2012 2:02 pm Up
Ookay... do you get 12V on the wires for rear, brake etc, just outside the cluster? With the indicator working, the grounding for the cluster appears OK - possibly a broken ground internal to the cluster...
But the non working front sidelight at the same time makes it weird...
Fear you'll need to trace and probe the wiring and see how far you have voltage/where it disappears.
At the front, is there +12V in the lamp socket? Good connection between the other pin in the socket and good ground (neg battery pole)?
HTIDJamie
PostPosted: Thu Jul 19, 2012 2:37 pm Up
check the bulbs aswell because sometimes 1 bulb could shorten a few bulbs out isounds weird but it happend on my saxo ,
oh the joys of french cars :L
jp
PostPosted: Thu Jul 19, 2012 3:06 pm Up
Check that it is the correct bulb for the lights. P21/5 for standard lights (2 connectors on the base)
LiamGTi180
PostPosted: Thu Jul 19, 2012 4:45 pm Up
Could be the bulbs. I put the wrong ones in my saxo and everytime I went to brake the front fogs came on ha
