Online Now [1073]:
Visitors: 1072
Today: 163061
Total: 151649203
Forums › The Car › Request a how-to › how to remove upper front grill (with badge)
jk206
PostPosted: Fri Jul 20, 2012 9:03 am Reply with quote Up
how do i remove the front grill on a 206? as i need to replace the near side headlight and to do so i need to take this off. pictures would be great
cheers
PostPosted: Fri Jul 20, 2012 9:28 am Reply with quote Up
a few bolt and just pull it out
PostPosted: Fri Jul 20, 2012 9:29 am Reply with quote Up
Take the mushroom clips off, and it pops off at either side.
5 minutes tops
PostPosted: Fri Jul 20, 2012 9:31 am Reply with quote Up
Remove the the black plastic clips which are just above the bonnet catch, then unscrew the bolts x2 (1 either side) of the badge itself then pull the edges of the grille where they meet the front wings
jk206
PostPosted: Fri Jul 20, 2012 9:41 am Reply with quote Up
as simple as that? cheers for help
PostPosted: Fri Jul 20, 2012 10:37 am Reply with quote Up
Its a Peugeot, they are basically held together with clips & torx bolts Laughing
L5_UKS
PostPosted: Fri Jul 20, 2012 10:46 am Reply with quote Up
What He Said
DeadEyePaul
PostPosted: Fri Jul 20, 2012 11:06 am Reply with quote Up
Ok it's pretty simple!
Open the bonnet and there's a plastic grill that has slats this is held on by 4 mushroom clips. My favourite tool to remove those is a fork. Once they are out at the bottom of that plastic slat thingy there are clips that you need to push in and at the same time you need to pull it out. Once you got them all out it will reveal a bolt hiding behind the Peugeot badge and there's 2 either side of the badge (3 in total)
Now you have to grab the edge of it (by the wing, below the headlight) and pull! Be warned it's held on by clips and those can be brittle, can buy replacements on the cheap from Peugeot parts! If you have strong finger nails you can tug it off by using those... If not something wrapped in duct tape will do (like a blockbuster membership card?) to stop scratching of the paint
HTIDJamie
PostPosted: Fri Jul 20, 2012 12:06 pm Reply with quote Up
u love your blockbuster membership cards dont ya Wink
i need to get one Very Happy
jp
PostPosted: Fri Jul 20, 2012 12:10 pm Reply with quote Up
If you break any of the plastic clips then a Peugeot / Citroen main dealer ( whichever is nearer to you ) will have them in stock & main dealer will be cheaper then getting ripped of on Ebay Wink
marc206
PostPosted: Fri Jul 20, 2012 3:21 pm Reply with quote Up
lukesaunders91 wrote:
What He Said
What He Said
206boyracer
PostPosted: Fri Jul 20, 2012 4:17 pm Reply with quote Up
Or just fill your pockets when you go scrapyard next. Whistle...
206 GTI 138.
jk206
PostPosted: Sat Jul 21, 2012 7:09 am Reply with quote Up
Got the grill off and headlight changed this morning, was easier than I thought!
  Quick Reply
Username:
Message:
Quote the last message
