Online Now [485]:
Visitors: 483
Members: 1
Today: 62009
Total: 152903424
Forums › The Car › Request a how-to › drilling out the lock barrel? to remove ignition barrel?
seany_brown
PostPosted: Fri Jul 20, 2012 5:49 am Reply with quote Up
Lost my keys but I have a new ecu and all locks changed except the ignition barrel, has anyone drilled one out or is there an easier way to replace the ignition barrel without drilling, cheers Sean
PostPosted: Fri Jul 20, 2012 6:02 am Reply with quote Up
You should have said, I could have supplied you with a key to match all your original locks.
PostPosted: Fri Jul 20, 2012 10:35 am Reply with quote Up
Get a key cut from the VIN number info then you can turn the ignition barrel to the service position & it will slide out.
PostPosted: Fri Jul 20, 2012 11:19 am Reply with quote Up
big ass screw driver also works, found that out on me old locks. Laughing Laughing
PostPosted: Fri Jul 20, 2012 11:20 am Reply with quote Up
Would have been far easier just to get new keys cut & coded Whistle...
PostPosted: Fri Jul 20, 2012 11:24 am Reply with quote Up
i had no door locks (had been removed by last owner) and barrel kept getting stuck. £10 for all the locks/barrel and keys from scrappy so couldnt moan lol. just had some fun with old one Smile
seany_brown
PostPosted: Fri Jul 20, 2012 12:54 pm Reply with quote Up
What info do I need to ggive to get a new key cut n coded ? And won't that cost a lot Sad
PostPosted: Fri Jul 20, 2012 1:07 pm Reply with quote Up
£32.50 and I'll get one shipped to your door.
Valet style key, matched to your locks and you can get it coded so it starts the car too!
  Quick Reply
Username:
Message:
Quote the last message
