Latest: Andyblue64
Overall: 17123
Online Now [427]:
Visitors: 426
Today: 25742
Total: 98112984
Forums › The Car › 206 Problems › Tinny rattle coming from exhaust
Jarret
PostPosted: Wed Jul 25, 2012 10:08 am Up
Hello
I have a tinny rattle coming from my exhaust. You can hear it most if you dip the clutch with the hand-break on.
It happens when pulling off or changing gears. The car is 02 plate 206 1.4 LX
Any ideas
Cheers
206 1.4 LX 2002
Jarret
PostPosted: Wed Jul 25, 2012 10:10 am Up
Just a bit of info. Ive had a new exhaust fitted. Ive been told it could be the engine mounts giving to much play and letting the exhaust move.
206 1.4 LX 2002
L5_UKS
PostPosted: Wed Jul 25, 2012 10:21 am Up
Exhaust could be vibrating on the heatsheild
Jarret
PostPosted: Wed Jul 25, 2012 10:25 am Up
Dont really know much about cars, where would i find the heat shield?
206 1.4 LX 2002
Jarret
PostPosted: Wed Jul 25, 2012 10:33 am Up
If its what i think it is, its not coming from that area, it seems to be coming from where the exhaust bots together with two springs.
206 1.4 LX 2002
MrZiggerz
PostPosted: Wed Jul 25, 2012 2:25 pm Up
That is what mine was doing at around 2000rpm.
I had mine upgraded to a Stainless Steel exhaust so, obviously it does not do it anymore.
DanT
PostPosted: Wed Jul 25, 2012 3:30 pm Up
There are various heatshields along the complete length of the exhaust system basicly, are you able to get the car up on stands and have a poke about underneath? Could check your bolts at the same time?
Jarret
PostPosted: Thu Jul 26, 2012 6:06 am Up
Ill have a look today and see what i can find.
206 1.4 LX 2002
Rob2859
PostPosted: Thu Jul 26, 2012 6:30 am Up
Its a Peugeot if the exhaust doesn't rattle it means its probably fallen off Very Happy
Best thing for you to do is jack the car up, get it rattling and feel your way down the exhaust holding and shaking it as you go and you will soon find it. Best do it with some gloves on when the engine is cold.
southwestchap
PostPosted: Thu Jul 26, 2012 6:32 am Up
could be that the exhaust is a bit close to the rear beam? i had that once...
PostPosted: Thu Jul 26, 2012 8:58 am Up
1.4 Lx? They all make that noise! Laughing
Jarret
PostPosted: Fri Jul 27, 2012 3:53 am Up
I jacked it up this morning and looked and sprayed some wd40 on the seals and the sound is gone!
206 1.4 LX 2002
Jarret
PostPosted: Fri Jul 27, 2012 2:40 pm Up
The sound has come back tonight!
206 1.4 LX 2002
James_sinovi
PostPosted: Wed Aug 01, 2012 2:15 pm Up
It will be the exhaust flexi joint - that is the joint with two bolts and springs that you sprayed with WD40. Inside the joint there is a circular metal sealing ring. When that gets old, rusts and wears away the joint starts to grind together and makes the squeaking you can hear.
Here's a pic of the old one from my car and new one I fitted side by side:
You can get a new one from pug if you want to fit it yourself. I think you have to buy the bolts and springs too so works out about £13.
