Online Now [670]:
Visitors: 669
Today: 15026
Total: 154227175
Forums › The Car › 206 Problems › Electric window switch
mattvaretto
PostPosted: Mon Jul 30, 2012 1:40 pm Up
So I took the cover for the above off to paint and the switch with the long plastic piece underneath still attached. When I went to replace it the switch works still but the switch doesn't automatically return to the middle like it should. I've tried taking it apart and refitting it together but still doesn't work. I ended up getting frustrated and just leaving it so any help would be massively appreciated!!
jk206
PostPosted: Mon Jul 30, 2012 1:44 pm Up
get a replacement off ebay, job done.
anton1989
Trade Rating: +16
just buy a new one £5 from scrap yard
mattvaretto
PostPosted: Mon Jul 30, 2012 1:55 pm Up
Thought about that but the wiring for the electric windows won't come out. It's got a metal surround on it and I can't remove the wires :s
PostPosted: Mon Jul 30, 2012 2:01 pm Up
The switch unplugs from the wiring loom.
mattvaretto
PostPosted: Mon Jul 30, 2012 2:14 pm Up
Will try again but didn't want to break it!
PostPosted: Mon Jul 30, 2012 2:23 pm Up
Press the clip on the connector plug & it will slide out.
For the electric mirror connector press the clip in then slide the lever down past it to unlock it.
iainlovatt
PostPosted: Mon Jul 30, 2012 3:27 pm Up
also that metal surround will also come off when the wiring loom is out!!
(My Garage)
anton1989
PostPosted: Mon Jul 30, 2012 3:28 pm Up
Trade Rating: +16
if you need another 1 one pm me, got one hear, £5 plus postage cost
