Latest: sparrowdclxvi
Overall: 17139
Online Now [736]:
Visitors: 735
Today: 101551
Total: 112785449
Forums › The Car › 206 Problems › Unblock diesel filter (replaced)
Go to page Previous  1, 2
darratt78
PostPosted: Mon Jul 30, 2012 1:48 pm Up
Yes Beru is what I used. Took an hour to fit them and next day a trip from Swindon to Thorpe park sorted it! Good luck.
206 hdi GTI
Boxerman
PostPosted: Mon Jul 30, 2012 1:56 pm Up
Also how will it know to regenerate? Do I need to do anything?
Pug 206 1.6 Sport 110 Owner
PostPosted: Mon Jul 30, 2012 2:05 pm Up
it detect the back pressure from the DPF, if it is higher than a certain unit (too much carbon clog up the filter) it will start to regenerate.
darratt78
PostPosted: Mon Jul 30, 2012 2:08 pm Up
I think the glow plugs are needed to provide the heat or start the heating process during re-gen. Obviously if the plugs aren't up to it then the process won't commence. Im not sure of the science involved, but for me the plugs failing was an easy solution, I'd rather change them than change the fuel cap sensor or even filling the fuel additive! Both jobs require the car to be in the air whereas with the plugs you can take your time. If your not confident best get a mechanic on them, check the 'how to' guides and decide! Engine block needs to be hot to remove them though or you will snap one!
206 hdi GTI
PostPosted: Mon Jul 30, 2012 2:23 pm Up
the plug was required to increase the exhaust gas temperature to get the regen. to proceed
darratt78
PostPosted: Mon Jul 30, 2012 2:27 pm Up
Thanks Seabook that makes sense now!
206 hdi GTI
Boxerman
PostPosted: Mon Jul 30, 2012 5:54 pm Up
Thanks for all your help guys!
Last question, what's the part number of glow plugs for my car?
2005 reg 206, 1.6 HDI Sport 110BHP?
darratt78
PostPosted: Mon Jul 30, 2012 10:36 pm Up
Go on GSF's website,put your reg number in at the top left and order them. They are 29 quid delivered I think. That's probably the best way to get them unless you have a store near you? Try and avoid the fakes or lesser quality eBay ones!
206 hdi GTI
Page 2 of 2
