Online Now [357]:
Visitors: 356
Today: 115162
Total: 155208798
Forums › The Car › Request a how-to › Request: Fitting SP Arches.
stickman
PostPosted: Tue Jul 31, 2012 5:58 am Reply with quote Up
as title states.
would like to know how to fit these, i have sent them off to be painted but i am not 100% on how to put them on, ive got screws supplied but no idea what they are for.
cheers
03 China Blue Dturbo
lmilligan
PostPosted: Tue Jul 31, 2012 6:06 am Reply with quote Up
you fix them on with clips mate, where did you get them from?
MrrNoName
PostPosted: Tue Jul 31, 2012 6:09 am Reply with quote Up
If they are official arches (not third party cheap Chinese ones) then they should have a number of rectangular holes on the inside.
You attach the supplied rubber strip to the side of the arch which touches the cars paintwork, then press the arch up against the car and clip the black metal clips around the rear of the arch and cars bodywork into the rectangular hole.
Standard arch fitting uses no screws.
Others on here have glued them on, riveted them on or even screwed them into the cars bodywork, but clipping means they can be removed with no damage to the car and works just as well (when done correctly) IMO.
Type "Peugeot 206 Wheel Arch Extension Fixing Clips" into eBay to see what they look like if needs be.
Hope that helps.
iainlovatt
PostPosted: Tue Jul 31, 2012 6:10 am Reply with quote Up
they are metal clips and you simple clip the arches on 5 minute job, whomever you bought them off has screwed them on by the sounds of it!
Personally would use clips with the arches.
Iain
(My Garage)
stickman
PostPosted: Tue Jul 31, 2012 7:03 am Reply with quote Up
that's great guys, thanks. i had them from a user on here a while ago but never got around to having them repainted and fitted.
cheers Smile
  Quick Reply
Username:
Message:
Quote the last message
