Online Now [730]:
Visitors: 728
Members: 1
Today: 120614
Total: 155416609
Forums › The Car › 206 Problems › Car idling Weird
Car idling Weird
Boywonder7
PostPosted: Thu Aug 02, 2012 1:15 pm Up
Looking for some help with my 1.1 batboy. Drove the car home from work yesterday fine.. Got into it this morning and was idling all over the place, Plugged the diagnostic machine in at work and threw up P0030 Code random misfire .. last time i got this code the coil pack had packed in so i changed it to no effect, iv also fitted injectors tonight but had to use the old wiring harness as the plugs were different. Car now sounds like its hunting but will rev up fine.
Any suggestions folks would be much appreciated before i loose patience with it?
Boy Wonder
anton1989
PostPosted: Thu Aug 02, 2012 1:57 pm Up
Trade Rating: +16
spark plugs?
which 1s do you have in?
Boywonder7
PostPosted: Thu Aug 02, 2012 2:04 pm Up
new plugs last week ngk BKR6EK plugs mate. Thinking maybe crank sensor
Boy Wonder
anton1989
PostPosted: Thu Aug 02, 2012 2:13 pm Up
Trade Rating: +16
there's your problem
ngk are no good, use bosch there loads of threads on it
Boywonder7
PostPosted: Thu Aug 02, 2012 2:14 pm Up
its not the plugs cars ran fine with ngks for at least the last 3 years
Boy Wonder
anton1989
PostPosted: Thu Aug 02, 2012 2:15 pm Up
Trade Rating: +16
well i say there's your problem, could be something else but have a read would start with sparks
CLICK HERE
Boywonder7
PostPosted: Thu Aug 02, 2012 2:20 pm Up
Decent read learn something new everyday will give it a shot see what happens will get them for nothing anyways cheers mate
Boy Wonder
anton1989
PostPosted: Thu Aug 02, 2012 2:24 pm Up
Trade Rating: +16
no worries
PostPosted: Thu Aug 02, 2012 2:44 pm Up
If it revs fine, but idles incorrectly it will most likely be the idle control valve.
Take it out and give it a clean with some WD-40 (or better)
Or maybe have to replace if it's bust
Boywonder7
PostPosted: Thu Aug 02, 2012 4:18 pm Up
got a lot of different things to try tomorrow thats defs one of them harry cheers
Boy Wonder
PostPosted: Thu Aug 02, 2012 5:18 pm Up
use carb cleaner..... not WD-40...
