Online Now [374]:
Visitors: 373
Today: 100577
Total: 155970589
Forums › The Car › 206 Problems › Whoops! Gearstick problem **Problem Solved**
206Mike
PostPosted: Thu Aug 02, 2012 2:45 pm Up
To cut the story of how it happened short, the gearstick pops up and down a lot more than it should do;
In its highest position, it can engage gear but doesnt feel to 'slot in' to gear.
The level below that it slots into gear but feels like moving a shovel through water, very unsure of itself.
When pushed down, a thud is heard/felt and the gearstick is back to its normal position, engaging gears fine etc. However when shifting and engine revs are above 2k itll pop back to the 'middle' position
Quick SOS call to a couple members on here suggests its either Rear engine mount (which seems fine, no odd movements or noises apart from a louder rattle at the 2k point) or gear linkages.
Basically, somethings hit the fan and smeared all over the room. Any ideas guys? Any help much appreciated.
Thanks to Dave for accepting my call and not thinking "WTF what an absolute moron" Very Happy
+8 Pos feedback Smile
PostPosted: Thu Aug 02, 2012 3:02 pm Up
did it happen in all gear or just in one particular gear?
206Mike
PostPosted: Thu Aug 02, 2012 3:10 pm Up
All gears Sad
Cartoonhead suggests maybe the ball on the bottom of the gearlever, looks like i may be doing some rooting around tomorrow!
Rob2859
PostPosted: Thu Aug 02, 2012 4:35 pm Up
The shits hit the fan for you then. (couldn't resist :D)
If the gearstick moves up and down a lot then inspect the balljoint like you said, it could even be loose bolts. I would check under the car first, grasp the rod, pull it, push it and give ita good shake Very Happy
PostPosted: Thu Aug 02, 2012 4:51 pm Up
would be fairly easily to check though.
206Mike
PostPosted: Fri Aug 03, 2012 12:47 pm Up
Problem solved! Gear linkage was f******g held together by cable ties. I'm not joking. About 100 cable ties. And i'm guessing its been like that for a while. Sorted it for now but thats one that definitely needs attention on Monday
PostPosted: Fri Aug 03, 2012 1:55 pm Up
get some decent steel cable tie and you will be fine
206Mike
PostPosted: Fri Aug 03, 2012 2:43 pm Up
They make steel cable tie?!?! Surprised
Rob2859
PostPosted: Fri Aug 03, 2012 5:32 pm Up
Ahhhh that is quite amusing.
I have supported my backbox with stainless cable ties before when I didn't have any hangers.
206Mike
PostPosted: Sat Aug 04, 2012 1:23 am Up
Wow! Did it work okay rob?
-Dave-
PostPosted: Sat Aug 04, 2012 2:27 am Up
Trade Rating: +36
Take a photo before you get it sorted Mike. I wanna see this lol.
Ex 206 Owner.
Rob2859
PostPosted: Sat Aug 04, 2012 5:39 pm Up
Yes but it was a temporary measure of course.
206Mike
PostPosted: Tue Aug 07, 2012 2:14 pm Up
Dave, the problems been sorted now. Properly Razz
It looked like this but imagine that a LOT more times until its just a ball of cable tie haha
PostPosted: Tue Aug 07, 2012 2:22 pm Up
alright. i was thinking is the linkage rod.
instead of the actual linkage on the box.
but hey, cable tie is just awesome Laughing
