Online Now [1321]:
Visitors: 1320
Today: 450476
Total: 153845352
Forums › The Car › 206 Problems › cebtral locking
cebtral locking
Neil206
PostPosted: Fri Aug 03, 2012 8:48 am Up
after removing my doorcards, mirror covers, sound deadening, speakers and wiring for auto mirrors, and audio, the remote central locking wont engage, i can only lock the car manuallly, and by moving the locking bar across in the boot before closing it
any ideas what ive done haha?
recently put the battery in the boot, but the locking was working fine as that was done 2 weeks ago
i cant even engage the alarm (smaller button on key)
cheers in advance, as usual
206
GuyGTI
PostPosted: Fri Aug 03, 2012 9:00 am Up
Does it lock and then unlock instantly? If so one of the motors has gone. If not, simple things like checking the fuse?
206 superchiped GTI
Neil206
PostPosted: Fri Aug 03, 2012 9:05 am Up
allf uses are ok and yes it does that but no indicator flash
206
Neil206
PostPosted: Fri Aug 03, 2012 9:08 am Up
just out of interest what number fuse is it for locking? its amp? and i presume the drivers kick footwell fusebox?
206
GuyGTI
PostPosted: Fri Aug 03, 2012 9:19 am Up
Yes its the drivers footwell box, cant rememebr which one it is, its in the haynes manual but you can probably google it. One of the lock motors that drives them up and down went in mine, replaced it myself and jobs a good'n!
206 superchiped GTI
Neil206
PostPosted: Fri Aug 03, 2012 9:21 am Up
all the motors the same ? presume there's 3? its a 3 door...
206
GuyGTI
PostPosted: Fri Aug 03, 2012 9:31 am Up
I believe so, my friend who works in a garage ordered them for me, just took 10 min to do, pop the door card off and replace the worn out motor, check which side is not working though, unsure if there is a left and right motor, got the feeling they are the same.
206 superchiped GTI
Neil206
PostPosted: Fri Aug 03, 2012 9:33 am Up
cheers ill look into it ?:) any physical way to tell whch moyors gne?
206
mtempsch
PostPosted: Fri Aug 03, 2012 10:04 am Up
Haven't had to do it myself, but from what I've read here on the site:
Disconnect them one at a time and test the other 2 for proper operation - if the 2 connected ones work OK, then the faulty one is the disconnected one.
Silvermetallic 2004 206 RC
Neil206
PostPosted: Fri Aug 03, 2012 10:10 am Up
haha just realised how simple tht is, feel a bit of a div now
206
GuyGTI
PostPosted: Fri Aug 03, 2012 12:34 pm Up
Hope you manage to sort it out!
206 superchiped GTI
Neil206
PostPosted: Sat Aug 04, 2012 3:53 am Up
tbh i might just remove it all, any ideas what i can do about making a suitable boot lock, as there's no physical key hole
206
Neil206
PostPosted: Sat Aug 04, 2012 12:28 pm Up
does the boot HAVE to be accesible from both saides for the mot (interior / exterior)?
206
broadblaster
PostPosted: Sat Aug 04, 2012 1:16 pm Up
yes the boot has to open from the outside
on a back road playing
Neil206
PostPosted: Sun Aug 05, 2012 11:45 am Up
cool cheers, ill just leave the car unlocked for its mot's
206
