Latest: sparrowdclxvi
Overall: 17139
Online Now [556]:
Visitors: 556
Today: 72875
Total: 112884467
Forums › The Car › 206 Talk › will a saxo sxhaust fit staight on to a 206?
HTIDJamie
PostPosted: Sat Aug 04, 2012 1:58 am Up
Basicly been offerd a peco exhaust from a saxo ,
just wondering if it would be a straight fit ( like ive been told )
or wether it would need to be welded ect ?
jp
DeadEyePaul
PostPosted: Sat Aug 04, 2012 2:02 am Up
Probably needs a little work, exhaust hangers for example or size of the pipe-will it fit on to yours... Yes but probably need a little modifying first.
HTIDJamie
PostPosted: Sat Aug 04, 2012 2:14 am Up
as far as im aware its not been chopped ect but like u say the hangers , ill probs leave it then , cba with all the choppin bull lol .
jp
PostPosted: Sat Aug 04, 2012 3:13 am Up
It's a completely different car...an exhaust from a Clio is likely to be as easy to fit.
