Posted: Sat Aug 04, 2012 2:22 am |
Morning All,
I've just downloaded and installed Pug Planet, my question is, i need to reset a counter to get the Unblock Diesel filter fixed, which one and how do i do it?
While i've got it hooked to the car, what else is recommended for me to do?
Tar chaps!
J
| Pug 206 1.6 Sport 110 Owner | |
Posted: Sat Aug 04, 2012 2:23 am |
I recommend you don't play with it unless you know exactly what you are doing. Otherwise you can have some very serious consequences.
Posted: Sat Aug 04, 2012 2:47 am |
did you got the cable?
Posted: Sat Aug 04, 2012 2:51 am |
I've got the cable yes.
Posted: Sat Aug 04, 2012 6:53 am |
may i ask where you got the cables from and there cost please?
Posted: Sat Aug 04, 2012 7:27 am |
What version of pp do you have, the dpf options will only be available on the newer version
Posted: Sat Aug 04, 2012 9:44 am |
I have 24.29 I believe.
Posted: Sat Aug 04, 2012 10:08 am |
GT > DPF > Maintenance > Eloys
Posted: Sat Aug 04, 2012 2:04 pm |
where did you download it from ? how much did it cost
Posted: Sat Aug 04, 2012 2:13 pm |
138Andy wrote: |
where did you download it from ? how much did it cost |
Its totally useless without the correct cable
Posted: Sat Aug 04, 2012 3:34 pm |
Posted: Sun Aug 05, 2012 4:30 am |
Posted: Sun Aug 05, 2012 5:34 am |
Trade Rating: +16
did this not have a bid the other day?
does the mean you wont be reading code etc anymore?
Posted: Sun Aug 05, 2012 5:48 am |
anton1989 wrote: |
does the mean you wont be reading code etc anymore? |
They removed it because I had autodata in the listing; so I had to relist.
More than likely no, definitely not on the same scale as before. Taking a step back from the car scene for a while, as I've got other things to do.
Posted: Sun Aug 05, 2012 7:28 am |
Disaster waiting to happen?
| Team Impossible Possible
