Online Now [483]:
Visitors: 482
Today: 141505
Total: 156493632
Forums › The Car › 206 Problems › Faulty Crankshaft Sensor
PostPosted: Sun Aug 05, 2012 7:06 am Up
Well as per usual being french my 206 has developed another fault, this time the problem has been picked up on the RAC's diagnostic computer as a faulty crankshaft position sensor.
Searching on eurocarparts I have found a crank angle sensor for £12.60 which reading the product information sounds like what i need.
Is this crank angle sensor another name for the crankshaft position sensor or is it a different item altogether?
PostPosted: Sun Aug 05, 2012 7:10 am Up
Different part. Crank sensor is on top of engine. Angle sensor is on pulley side I think?
PostPosted: Sun Aug 05, 2012 7:32 am Up
Part number 419770050 titled camshaft sensor is actually a crank sensor. I'm sure I didn't pay that much from the Peugeot dealer.
Crank angle and crank sensor are the same thing. They both tell the ECU the rotational position of the crank using the timing marks on the flywheel.
PostPosted: Sun Aug 05, 2012 7:40 am Up
The 2nd paragraph above is exactly what the rac bloke told me yesterday
PostPosted: Sun Aug 05, 2012 7:41 am Up
He knows his stuff!
PostPosted: Sun Aug 05, 2012 7:56 am Up
and yourself too mate, i just thought it was the ecu gone again because it was behaving the same as before only this time was unable to start engine
PostPosted: Sun Aug 05, 2012 8:16 am Up
Edward wrote:
He knows his stuff!
unlike me!
PostPosted: Sun Aug 05, 2012 8:25 am Up
im sure you do steve
PostPosted: Sun Aug 05, 2012 8:27 am Up
Obviously not! Or am I missing something?
The car won't start as the ECU can't detect the position of the timing. Will usually say Crank/Cam shaft un-synced in live data.
PostPosted: Sun Aug 05, 2012 11:48 am Up
Anyway, on a 1.4i at least, there is only crankshaft sensor unlike 138, 180 etc. which have cam shaft pos sensor as well.
Lee, it might be interminent no?
PostPosted: Sun Aug 05, 2012 11:50 am Up
Possibly, but it should tell you when you code read.
Sometimes just needs the sensor cleaning.
