Posted: Mon Aug 06, 2012 4:00 pm |
my question is about the crankshaft sensor, when I start the 206 it runs fine, but if it stalls then it wont start for a while, warm or cold. I had something similar with a renault scenic. it turned out the crankshaft sensor is prone to causing problems and they need cleaning.
Does the 206 sensors also have the same problems?
Posted: Mon Aug 06, 2012 4:14 pm |
not an uncommon fault on 206
Posted: Tue Aug 07, 2012 11:32 am |
I took the sensor off and cleaned it up, but same problem.
Have to just try the glow plug relay first, although it did come on once yesterday.
