Latest: elelectricistadeMateo
Overall: 17127
Online Now [65]:
Visitors: 64
Today: 23592
Total: 100396268
Forums › The Car › 206 Problems › Stuck torsion bar
Stuck torsion bar
Fifer
PostPosted: Tue Aug 07, 2012 7:58 am Up
Hi all,
After changing the drivers side trail arm bearings the time has come to do the passenger side. I have hit a major snag though and that is the upper torsion bar will simply not move.
I have hammered the hell out of the trail arm, tried hitting the bar, heat and rust oil but still no movement. Not even the slightest give.
At the moment I have a socket and bolt sitting with some tension on the bar overnight but I'm not holding out much luck. When I hammer the trail arm, the arm moves slightly out at the bottom but the top doesn't budge where the torsion bar is holding tight. Both screws and shaped washers are removed.
Does anybody have any other ideas for freeing this damm thing up.
I'm getting that annoyed by the thing I was thinking of cutting it in two to get the trail arm off and then getting a replacement torsion bar.
1.4hdi 02
PostPosted: Tue Aug 07, 2012 8:11 am Up
up to you but just to let you know i got a spare set of GTi torsion bar.
blow torch, WD-40 and hydraulic press is quite handy.
bigger hammer also help
Fifer
PostPosted: Tue Aug 07, 2012 8:21 am Up
Sods law, but in a good way.
IT'S FINALLY OUT.
So much harder than the otherside. It seems some pentatron heat and waiting worked. Thanks for the reply Seabook.
1.4hdi 02
PostPosted: Tue Aug 07, 2012 8:25 am Up
IT'S FINALLY OUT.
well done.
yes for some reason one of the torsion bar always more difficult to come out.
