Latest: dreyfalon
Overall: 17121
Online Now [563]:
Visitors: 562
Today: 75509
Total: 97375508
Forums › The Car › 206 Problems › 206 180 intermittent starting problems
Headtrauma
PostPosted: Tue Aug 07, 2012 9:44 am Up
Hi all, had my 180 for a year and a half now and love it to bits.
Am getting a problem when starting it, sometimes nothing happens when I turn the key apart from a hopeful 'click' from the solenoid. It bumps first time, tried rocking it in gear to move the starter position and battery is fine.
First thought was 'brushes' so I went to investigate, starter motor is hidden away under the inlet manifold?? (should have expected that having owned a 205 gti!!)
Have checked battery strap resistances (both seem fine)
So to cut to my questions:
1) Is it possible to get at the starter without removing the inlet manifold?
2) Anyone experienced a similar problem and have any suggestions that I may of overlooked?
Thanks guys Smile
206 Gti 180sp\r\nStill scares me Smile
NICKST
PostPosted: Tue Aug 07, 2012 11:01 am Up
Most likely a starter motor problem. Or some times can happen if u try a start it up straight away wait for lights to go out my old one was quite touchy like that lol you haven't got my old one have you lol
Headtrauma
PostPosted: Tue Aug 07, 2012 12:47 pm Up
Lol, might be.. Only met the blokes wife but it had 46k on the clock when I bought it.
I've been waiting for dash lights to go off and fuel pump to stop :-/
Really just want to know if there is a way to get at the starter without removing quarter of the engine Smile
Should have known I'd need to buy an entire set of wiring and a huge pot of Vaseline to smear all the connections (because as everyone knows it never rains in France so they don't plan for wet weather and the effects it has on a car!)
NICKST
PostPosted: Tue Aug 07, 2012 1:56 pm Up
I think u have to take the inlet manifold off to get to the starter it's a easy job just time consuming lol
Headtrauma
PostPosted: Wed Aug 08, 2012 5:26 am Up
Bummer..
Thanks mate Smile
Headtrauma
PostPosted: Thu Sep 27, 2012 7:39 pm Up
Solved.
Dismantled, removed starter (a job which I can confirm require removal of inlet manifold of on 04 model at least!) and cleaned out quite a lot of worn magnet from said starter, which must have been jamming the starter in place untill bumped or jolted sufficiently.
I've lubricated it and refit.
Working sweet as a nut
Saved £300 Smile
