Forums › The Car › 206 Problems › cooling fan sensor |
Posted: Thu Aug 09, 2012 6:16 am |
does anyone know where this is on a 1.4hdi as its not on the radiator and my fans don't cut in anymore
Posted: Thu Aug 09, 2012 11:54 am |
Bump if you're still here and want to know..
Posted: Thu Aug 09, 2012 12:11 pm |
If it's like other 206's it uses the coolant temp sensor to tell the ECU the temperature. If it goes above a certain amount it switches the relays behind the front bumper to switch the fan on.
