Latest: dreyfalon
Overall: 17121
Online Now [483]:
Visitors: 482
Today: 44289
Total: 97344351
Forums › The Car › 206 Problems › cooling fan sensor
cooling fan sensor
pudgie
PostPosted: Thu Aug 09, 2012 6:16 am Up
does anyone know where this is on a 1.4hdi as its not on the radiator and my fans don't cut in anymore Sad
my other cars a delica
PostPosted: Thu Aug 09, 2012 11:54 am Up
Bump if you're still here and want to know..
PostPosted: Thu Aug 09, 2012 12:11 pm Up
If it's like other 206's it uses the coolant temp sensor to tell the ECU the temperature. If it goes above a certain amount it switches the relays behind the front bumper to switch the fan on.
