Online Now [1064]:
Visitors: 1063
Today: 167352
Total: 150005351
Forums › The Car › 206 Talk › My Car dislikes new Spark Plugs..
Forum Index › 206 Talk
kiph
PostPosted: Thu Aug 09, 2012 12:40 pm Up
Right - I posted previously here about me swapping my old NGK plugs for some new Bosch Super Plus, this resulted in the car not starting from hot. Put the old NGK ones back, it was fine.
So I got some new NGK plugs and put them in.. similar problem! Although not quite as bad as the starting issues I had with the Bosch ones. Again, put the old plugs back, and it works fine! Obviously I don't want the old plugs to stay in the car as they've been in there a while. Could the Coil Pack be on the way out? I'm at a loss!
Kip - 2001 - 206 GLX - 1.6 - 16v - 110BHP
PostPosted: Thu Aug 09, 2012 12:41 pm Up
what plug did you get?
kiph
PostPosted: Thu Aug 09, 2012 12:49 pm Up
The Bosch Ones had the part no. 0 242 229 797
And the NGK ones are what Euro Car Parts Recommend their P/N - 408773460
K
NICKST
PostPosted: Thu Aug 09, 2012 4:41 pm Up
Got to main dealers and get them from there.
Rob2859
PostPosted: Thu Aug 09, 2012 7:18 pm Up
See if you can get the plugs exchanged, if the problem persists its probably the coil back but get a code reader on it before you put it in the bin.
