Online Now [2053]:
Visitors: 2051
Bots: 2
Today: 151171
Total: 152189831
Forums › The Car › 206 Talk › Need new wiper blades
Forum Index › 206 Talk
Nosvartu
PostPosted: Fri Aug 10, 2012 2:38 am Up
Hey guys just a quick question, i really need some new wiper blades and i thought id get the upgraded blades so i found these on ebay
www.ebay.co.uk/itm/Peu...486wt_1271
Will these fit my car?
How easy are they to fit?
Newby
iainlovatt
PostPosted: Fri Aug 10, 2012 3:02 am Up
Yes they will fit, but they are very cheap and probably going to be crap right from the start, but they would look good. The ones you should get are the bosch areo wipers!
(My Garage)
jk206
PostPosted: Fri Aug 10, 2012 3:11 am Up
I got these wipers off ebay and they work perfectly. A lot better than standard wipers!
glenpring
PostPosted: Fri Aug 10, 2012 3:12 am Up
dont go for that redline stuff brought a set just for mot and they fail being brand new
PostPosted: Fri Aug 10, 2012 3:58 am Up
Try these Bosch 21"/21" form ebay. A bit dearer but worth it for the quality.
I made the mistake of buying cheap aeroflats and they didn't last the winter. Moved onto these and not had a problem. Got a spare pair sat in the shed ready for winter and just ordered a 3rd set to go on my dads 206.
Also don't buy 22" aeros as you will have problems with the overhang at the edge of the screen. The 21" blades don't quite follow the shape of the screen but it's only a tiny bit near the bottom corner so doesn't make any difference to your vision.
Nosvartu
PostPosted: Fri Aug 10, 2012 4:15 am Up
Cheers guys Very Happy
I might buy the cheap ones see how they are and then if they really are bad ill just buy the others.
Newby
PaddyC
PostPosted: Fri Aug 10, 2012 7:38 am Up
I bought cheap-o 22" ones from a local shop and whilst they work fine they are too big and I have overhang and they judder quite a bit which is really annoying. I think when I go to get new ones I'll get the 21" Bosch's instead.
Peugeot 206 1.4HDI Style
kurosagi01
PostPosted: Fri Aug 10, 2012 9:19 am Up
Bosch Aerotwins all the way man. Definitely worth it.
PostPosted: Fri Aug 10, 2012 9:51 am Up
I've gone of Bosch wipers, the wiper quality has gone downhill the last couple of years.
Im trying Valeo flat baldes at the moment & there working fine so far.
kurosagi01
PostPosted: Fri Aug 10, 2012 10:17 am Up
On topic of bosch,i think i've notice slight drop in quality too. The 1st pair of aerotwins that was on 206 was dead quiet when in operation,the ones on now has slight bit of noise but still decent. Still better than standard wipers though.
Nosvartu
PostPosted: Fri Aug 10, 2012 10:22 am Up
Valeo flat wipers are for the 307 aren't they? do they actually fit a 206?
Newby
kurosagi01
PostPosted: Fri Aug 10, 2012 10:23 am Up
I'm sure they sell retro fit blades for 206? Just need make sure you get right size too.
anton1989
PostPosted: Fri Aug 10, 2012 2:22 pm Up
Trade Rating: +16
same here
although i broke one swapping them off my old 206 Wall Bang
as for the cheap ones, buy cheap, buy twice
PostPosted: Fri Aug 10, 2012 4:05 pm Up
They do, just get the correct fitment.
Nosvartu
PostPosted: Fri Aug 10, 2012 4:07 pm Up
I've decide to go for the more expensive ones but which is better between bosch or valeo ones?
Newby
