Posted: Fri Aug 10, 2012 9:14 am |
Posted: Fri Aug 10, 2012 9:50 am |
Fuse will be blown, look at the fuses in the cabin fusebox - common issue when people mess around with the stereo on multiplexed 206's.
206 immobiliser doesnt stop the starter turning.
As for the cut yellow cable, solder & heatshrink it back together.
Its also a good idea when working on the elctrical side of a multiplexed 206 to shut the BSI unit down correctly & disconnect the battery
Posted: Fri Aug 10, 2012 9:57 am |
Couldn't see any blown fuses but I'll go and have a look - the sidelights come on as soon as the ignition is turned on, although they're in the off position if that means anything?
Posted: Fri Aug 10, 2012 10:02 am |
Josh93 wrote: |
Couldn't see any blown fuses but I'll go and have a look - the sidelights come on as soon as the ignition is turned on, although they're in the off position if that means anything? |
Your 206 is multiplexed / digital CAN VAN electrical system.
Sidelights on by themselves means the BSI has detected loss of communication from a node on the CAN VAN system, most likely the immobiliser circuit that runs through the com2000 unit.
Check the fuses first BUT shut the BSI unit down correctly then disconnect the battery - DON'T just pull fuses out the fuse box as you can crash the BSI software / kill the BSI unit & it then gets expensive to sort out
Just like a computer, multiplexed 206's dont like there electrical systems being fiddled with / fuses being pulled on a live system
Posted: Fri Aug 10, 2012 2:03 pm |
Any mechanic should have been able to spot this! Check them carefully, they could look fine.
