Latest: Andyblue64
Overall: 17123
Online Now [146]:
Visitors: 145
Today: 34713
Total: 98789718
Forums › The Car › 206 Problems › Shaking wing mirror!!
brabus4
PostPosted: Fri Aug 10, 2012 5:06 pm Up
I've googled this and found several people that have suffered the same type of issue . . . when driving, my passenger side wing mirror shakes, making it very difficult to see properly.
I've checked it out as best as I can and it's definitely the plastic housing, not the mirror section. It looks like something needs to be tightened up maybe?
Anyone got any ideas??
Cheers. Very Happy
206boyracer
PostPosted: Fri Aug 10, 2012 5:12 pm Up
Open your door and Pull off the plastic cover from behind the mirror. (the cover with the tweeter in or manual adjuster on) There are 3 torx screws behind. Try tightening them up!
206 GTI 138.
gaffa786
PostPosted: Fri Aug 10, 2012 5:18 pm Up
What He Said
brabus4
PostPosted: Fri Aug 10, 2012 5:54 pm Up
Cheers guys, I'll try that tomorrow and update on how I get on. Smile
DeadEyePaul
PostPosted: Fri Aug 10, 2012 7:30 pm Up
Mine shake but that's due to my music being too loud
anton1989
PostPosted: Sat Aug 11, 2012 1:21 am Up
Trade Rating: +16
My drivers side does this, started after I fitted new wing mirros (180 folding ones) very annoying when driving, its nothing to do with torx screws in my case, its the mirror that shakes not the plastic, let me know if you fix yours as I have not a clue
brabus4
PostPosted: Sat Aug 11, 2012 9:08 am Up
It's not my mirror that shakes, it's the entire plastic casing from where the mirror folds in. The mirror glass is solid enough. Tried tightening screws, but no joy.
No idea why the mirror housing is slack, but I definitely need to sort it out, drives me crazy when I'm out and about! Just don't fancy paying over the odds for a new mirror when there could be an easy fix . . .
PostPosted: Sat Aug 11, 2012 12:29 pm Up
There are also 3 mini-torx screws on the outside underside of the mirror casing itself.
They are covered by mini rubber bungs which once taken-off reveal the screw heads beneath.
Even if they appear 'tight', give them a super-good twist and shake will be gone..
brabus4
PostPosted: Sat Aug 11, 2012 1:06 pm Up
Yeah I tried this too, but they were so tight that they couldn't be tightened any more. It's doing my head in now! Haha.
PostPosted: Sat Aug 11, 2012 6:19 pm Up
Try again, use a good tool and put some effort into it.
It's definately those if it's shaking at the 'folding pivot' but you have to tighten them like hell,
even if they feel rock-solid.
GL. Wink
brabus4
PostPosted: Sun Aug 12, 2012 10:35 am Up
GL. Wink
Tried again, no joy! Crying or Very sad
It's as tight as it's ever going to be, so god knows what's causing it to shake. Can't live with it, that's for sure . . . it's driving me mental!
PostPosted: Sun Aug 12, 2012 10:46 am Up
Get a new wing mirror then? Someone must have hit it previously.
