Latest: dreyfalon
Overall: 17121
Online Now [311]:
Visitors: 310
Today: 50097
Total: 97730627
Forums › The Car › 206 Talk › bonnet liner
bonnet liner
lisa206
PostPosted: Sat Aug 11, 2012 4:20 pm Up
What will happen if i remove the bonnet liner from under the bonnet? (that carpet thing)
Will the heat melt the bonnet ?
LISA 206 180
t1mmy
PostPosted: Sat Aug 11, 2012 4:21 pm Up
It will be fine.
PostPosted: Sat Aug 11, 2012 4:22 pm Up
if the heat can melt the bonnet surely your engine would have melt first.
in that case it will be a cat A write off.
so cut it short nothing would happen.
206boyracer
PostPosted: Sat Aug 11, 2012 4:27 pm Up
Took mine off ages ago. They always start to sag in the middle. Mine was rubbing on the air box and inlet elbow. No problems with getting rid of it. Weight saving too lol.
206 GTI 138.
lisa206
PostPosted: Sat Aug 11, 2012 4:31 pm Up
kk thank you
LISA 206 180
138Andy
PostPosted: Sat Aug 11, 2012 7:30 pm Up
its only there to absorb noise anyway Razz
PostPosted: Sun Aug 12, 2012 1:09 am Up
It also absorbs the water when the washer jet starts leaking and prevents the water causing problems with the injector.
138Andy
PostPosted: Sun Aug 12, 2012 6:26 am Up
why would your washer jet start leaking
DeadEyePaul
PostPosted: Sun Aug 12, 2012 7:00 am Up
mine were not spraying properly and was running down the bonnet. it made pretty patterns on my bonnet at high speeds
