Posted: Sat Aug 11, 2012 4:20 pm |
What will happen if i remove the bonnet liner from under the bonnet? (that carpet thing)
Will the heat melt the bonnet ?
Posted: Sat Aug 11, 2012 4:21 pm |
It will be fine.
Posted: Sat Aug 11, 2012 4:22 pm |
if the heat can melt the bonnet surely your engine would have melt first.
in that case it will be a cat A write off.
so cut it short nothing would happen.
Posted: Sat Aug 11, 2012 4:27 pm |
Took mine off ages ago. They always start to sag in the middle. Mine was rubbing on the air box and inlet elbow. No problems with getting rid of it. Weight saving too lol.
Posted: Sat Aug 11, 2012 4:31 pm |
kk thank you
Posted: Sat Aug 11, 2012 7:30 pm |
its only there to absorb noise anyway
Posted: Sun Aug 12, 2012 1:09 am |
138Andy wrote: |
its only there to absorb noise anyway |
It also absorbs the water when the washer jet starts leaking and prevents the water causing problems with the injector.
Posted: Sun Aug 12, 2012 6:26 am |
why would your washer jet start leaking
Posted: Sun Aug 12, 2012 7:00 am |
mine were not spraying properly and was running down the bonnet. it made pretty patterns on my bonnet at high speeds
