Online Now [393]:
Visitors: 393
Today: 118721
Total: 154676733
Forums › The Car › 206 Problems › what to use to re-attach the inner white door liner?
PUGPAUL
PostPosted: Sat Aug 11, 2012 4:49 pm Up
i.e. like polystyrene foam.
many thanks!
Peugeot 206 HDi (1.4cc) 'eco' - 2005
iainlovatt
PostPosted: Sat Aug 11, 2012 4:56 pm Up
duck tape!
(My Garage)
PostPosted: Sat Aug 11, 2012 5:01 pm Up
foam tape, tiger seal, epoxy.....it's all up to you.
PUGPAUL
PostPosted: Sun Aug 12, 2012 6:34 am Up
WHAT ABOUT this?
tape
Rolling Eyes
DeadEyePaul
PostPosted: Sun Aug 12, 2012 6:43 am Up
yeah that will do, or you could just get some glue.
cobs06
PostPosted: Sun Aug 12, 2012 7:38 am Up
or put the door card on with it and hope it stays in place
206 HDI
DeadEyePaul
PostPosted: Sun Aug 12, 2012 7:39 am Up
exactly who is going to see it once the doorcard is back on Rolling Eyes
PostPosted: Sun Aug 12, 2012 8:39 am Up
Seeing as you haven't got a clue what the white liner is actually there for keep your stupid suggestions to yourself Wink
cobs06
PostPosted: Sun Aug 12, 2012 9:12 am Up
Its for not letting water though to the door panel but I'v been out and took mine off and reattached it and it wouldn't do much it would most probably soak up the water and plastic does not get damages with water damage and you can dry the door panel up. I prefer to have it leaking into my car than it being not let through so i no a seal has gone and then i can sort it before it starts to rust.
206 HDI
PostPosted: Sun Aug 12, 2012 12:10 pm Up
Have it leak into the car and p**s your carpets through so they start smelling like a wet dog and begin rotting because you can't be bothered to take the carpets out to dry them properly everytime it rains
or
just make sure the drain holes are free from crap in the bottom of the door so the doors don't fill up with water in the first place.
PUGPAUL
PostPosted: Sun Aug 12, 2012 12:39 pm Up
I don't think the polystyrene foam which the door liner is made of actually absorbs water? If it did act like a sponge the metal door to which it is attached would, as someone has rightly said - 'rot away' and make the carpets irretrievably damaged and in turn begin to rot the metal floor and smell [awful]. These are probably reasons why this material was chosen in the first place and made water tight with sealant/adhesive from a cartridge type gun?
My point being "what can I get to replicate this 'in house' manufacturing process?"
P U Bonding Adhesive?
cheers!
PostPosted: Sun Aug 12, 2012 12:41 pm Up
Didn't think they were that expensive from Pug?
PostPosted: Sun Aug 12, 2012 1:17 pm Up
I just used a tube of bathroom sealant. Got it from the pound shop but can't remember how much it was. Confused
PUGPAUL
PostPosted: Sun Aug 12, 2012 1:41 pm Up
are they complete with the adhesive already on the back? [with a peel off protector over the adhesive part]
OR
do peugeot provide the liner and adhesive seperately?
my liner isn't in to bad a shape, it's in reasonable condition anyway!
PUGPAUL
PostPosted: Sun Aug 12, 2012 1:43 pm Up
Thumbs Up
