Latest: Flyin180
Overall: 17116
Online Now [24]:
Visitors: 23
Today: 5186
Total: 95023328
Forums › The Car › 206 Problems › Engine management Light on!
A10PSW
PostPosted: Sun Aug 12, 2012 2:19 am Up
Just recently my car would start then cut out then would be hard to start again, and now the Engine Management light has come on on the dash.
Any ideas anyone?
I have only just had it serviced and a timing belt change and it was running fine for about a week, once it does get started it sounds fine (no misfire).
Garage says its not anything they have done!
PostPosted: Sun Aug 12, 2012 2:26 am Up
Get the codes read otherwise it's like p**sing in the wind trying to guess what the fault might be.
A10PSW
PostPosted: Sun Sep 30, 2012 7:57 am Up
Fault was found to be a worn fuel pipe underneath the air box appantly it is a common problem which I fixed myself by cutting the fuel pipe where it was worn and fitted inline connectors for £3.00.
