Latest: flipflap
Overall: 17140
Online Now [232]:
Visitors: 231
Today: 86586
Total: 113886446
Forums › The Car › 206 Problems › Car won't start and then revs just drop......help please!
luke030588
PostPosted: Sun Aug 12, 2012 3:24 pm Up
Basically every now and again my car won't start first time, then when it does start everything resets (time and Date etc) and the revs will drop to zero and the car will cut out unless I give it some gas. After a while the problem goes away and the car won't go below 1k revs.
Have been told it's the battery but someone else has told me it's not. Any ideas?
04 plate silver, gloss black nimrods, 180 brakes, more to come.....
Rob2859
PostPosted: Sun Aug 12, 2012 4:03 pm Up
Probably the battery yes. My 206 never held on idle if the battery was flat. Sway is with someone else's to try it.
00budham00
PostPosted: Sun Aug 12, 2012 5:11 pm Up
Defo Battery I had this
PostPosted: Sun Aug 12, 2012 7:03 pm Up
Battery on it's last legs.
PostPosted: Mon Aug 13, 2012 12:33 am Up
do you hear a "bong" voice when u start it and do that?
gdon
PostPosted: Mon Aug 13, 2012 7:39 am Up
I had this problem once, the negative connection on the battery was loose so all i did I tightened it
luke030588
PostPosted: Mon Aug 13, 2012 1:15 pm Up
Yeh makes a noise and then the time and date reset, thanks for the help guys I'll get a new battery!
PostPosted: Wed Aug 15, 2012 11:18 pm Up
so did you got a new battery?? hope that sorted your problem Smile
