Latest: heikkisj
Overall: 17126
Online Now [52]:
Visitors: 51
Today: 3120
Total: 100200804
Forums › The Car › 206 Problems › 206 door lock problem ? :/
138Andy
PostPosted: Wed Aug 15, 2012 5:32 am Up
the driver side door locking thingy that pops up and down is sitting 2-3mm above the door card ? and im un sure if you can adjust this :/
PostPosted: Wed Aug 15, 2012 5:39 am Up
Its just a plastic lump pushed in to a metal rod.
Try & push it back down BUT be careful & dont bend the rod out of shape!
138Andy
PostPosted: Wed Aug 15, 2012 5:58 am Up
i know lol , i removed the door cards, im putting them back on now and it sits higher than it used to :/ , its not bent or anything :/ im not sure whats wrong with it lol pressing down locks it , but then even when its locked its sitting at the unlock position :/
PostPosted: Wed Aug 15, 2012 6:01 am Up
Sounds like its catching on something after the door card has been moved, have another look Wink
138Andy
PostPosted: Wed Aug 15, 2012 6:50 am Up
the passenger sides the same o.O both just sitting over the door card :/ might bend it a little and shorten it down , or remove it all together and smooth the hole till i wrap over it
138Andy
PostPosted: Wed Aug 15, 2012 10:26 am Up
Ok couldnt fix the problem so iv pulled it out and smoothed over it, will look s**t for a bit until i get some black & orange vinyl
