Latest: Andyblue64
Overall: 17123
Online Now [520]:
Visitors: 519
Today: 77291
Total: 98164486
Forums › Tuning, Modification & Legal › Project Cars › 205 GTI180 Supercharged
205GTi180
PostPosted: Sun May 27, 2012 2:32 am Up
yes i am. Its Matt, you had my old vts dash of me i think? Very Happy
205 with Supercharged GTI 180 lump 374 bhp...soon to be 400+
ryanovsalford
PostPosted: Sun May 27, 2012 8:40 am Up
this things going to be like a rocket love it keep up the hard work doing a good job
Nimminz
PostPosted: Mon May 28, 2012 2:51 pm Up
This looks a very nice project, love the work you've done. The only thing i wondered about is the stainless bolts in the suspension. What tensile strength were the originals? AFAIK even A4 grade stailess is only equivalent to ~6.8 whereas most suspension systems I've worked with are 8.8 at least. Not a criticism at all mate, just wondering.
One of the best projects i've seen on here recently!
2.0 8v RWD
205GTi180
PostPosted: Tue May 29, 2012 2:57 pm Up
If you take a closer look all at the critical bolts (suspension/wishbones/ball joints/ARB/caliper bolts etc) they are all oringinal spec bolts (8.8 and 12.9). The only ones that are stainless on the suspension are the top mount bolts which A4 stainless cap heads are more than upto the job for.
Thanks for bringing it up though as i have seen people using the wrong grade bolts on suspension components.
Ali_H
PostPosted: Tue May 29, 2012 4:42 pm Up
Awesome conversion.
kurtis wrote:
shell-vt
PostPosted: Thu May 31, 2012 2:42 am Up
Trade Rating: +46
yer ... what rear beam are you useing .. thers usually x1 or2 309 beams on 309gti goodwood owners forum is boring but some good bits come up..
york 16,3
205GTi180
PostPosted: Sat Jun 02, 2012 3:44 am Up
205 beam with 25mm ARB and Bilstein grp n tarmac shocks.
Dont see the point in running a 309 beam without using 309 front end, i wont do that as i have custom shafts already so would need another wider pair.
205GTi180
PostPosted: Thu Jun 14, 2012 1:04 pm Up
Here's a few pics and vids from the cars first proper test day at Santa Pod. I managed to pull some good times, was averaging low 13s but my best was a 12.7 @ 117mph.
www.youtube.com/watch?...detailpage
I also found this video somebody had uploaded to youtube
Schumi
PostPosted: Thu Jun 14, 2012 2:52 pm Up
Amazing. Did you ever done compression test on that engine. If you did can you remember how much bar or psi showed on gauge?
2005 206 RC RED
v6saloon
PostPosted: Fri Jul 06, 2012 11:38 am Up
Hi mate, ive got a sorrento 205 with the 180 lump, i would love to supercharge it, were all the bits hard to source? Anything that needed fabricating? Any help is much appreciated, here is a pic i159.photobucket.com/a...C00169.jpg
Ew10j4s 205 gti
spike_202
PostPosted: Fri Jul 06, 2012 12:28 pm Up
nice to see the car and have a chat about the car at fcs, I was with my mate with the 'green monster' 205.
**spike's project**
TEAM:+200bhp
Andrew
PostPosted: Fri Jul 06, 2012 1:42 pm Up
Love how clean everything about this is, specially the engine bay
My 206 thread
www.detailedbyandrew.com
205GTi180
PostPosted: Wed Aug 15, 2012 12:22 pm Up
When did you buy that?. As far as i know Lee (repairgeot) bought it back as he originally built it. I heard it was having a v6 fitted now.
205GTi180
PostPosted: Sun Jan 26, 2014 12:09 pm Up
Not updated this for a long time and a lot has changed!!.
The car was running 320 bhp when mapped but had the potential to make a lot more!. With the engine internally standard this was always going to be a test to see how far i could push it. I decided to up the boost and rev limit and it made 374bhp at 12psi (got to love high comp and boost Laughing )
Next up is a rear coilover conversion. Many benefits over torsion bars, easy ride height adjustment, options of spring rates, 1-1 damper ratio and save a lot of weight!!
8" wide Revolutions with 225 tyres all round
After 3 more trackdays finally found the limit of the EW10J4S engine
I dropped another standard engine in and restricted the power back down for the Nurburgring and a few more trackdays.
Nurburgring!!
On my last trackday the engine started missing and ran very rough. After checking all electrics etc i did a compression test and found no comp on cyl 1. At first i thought it was the head gasket because i put a camera down the spark plug hole and all looked fine. After pulling the head off i found 1 slightly bent inlet valve??. I can only put that down to high revs and unreliable hydraulic lifters and vvt system.
The recent problem has helped make my decision on which direction i want to go on a new forged engine. Original plans were to build a forged bottom end with standard head as they do flow well. I'm now going down the route of fixed cams (remove vvt) solid lifters, stainless valves etc.
206gt160
PostPosted: Mon Feb 08, 2016 4:46 pm Up
Brilliant effort for thia build. Was the car ran on standard gaskets as well as internals? I saw this setup for sale on ebay recently.
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
Page 3 of 4
