Latest: heikkisj
Overall: 17126
Online Now [66]:
Visitors: 65
Today: 6491
Total: 100204153
Forums › The Car › 206 Problems › GTi Power steering hose/pipe
Mounty
PostPosted: Wed Aug 15, 2012 3:15 pm Up
Got a slight leak in mine. Is the pipework the same on all 206's? Its the metal pipe thats leaking under radiator. Easy to change? Or is there any magic gunk I could repair pipe with?
2001 206 Gti - Original & Unmolested
1994 Renault 5 - Production Car Trials
PostPosted: Wed Aug 15, 2012 3:23 pm Up
I have the pipes off my gti im breaking
Pipe needs replacement, sticking stop leak stuff in will only cause more expensive problems in the future.
PostPosted: Wed Aug 15, 2012 3:26 pm Up
i might be wrong but i though your aren't suppose to reuse the pipe once it has been taken off?
PostPosted: Wed Aug 15, 2012 3:27 pm Up
Technicaly thats for the HDI high pressure fuel pipes.
For power steering pipes as long as there isnt any dirt / debris inside the pipe work it will be fine to reuse.
PostPosted: Wed Aug 15, 2012 3:33 pm Up
ar ha. i know i must have got confused with that Laughing
PostPosted: Thu Aug 16, 2012 12:58 am Up
Somewhere like Pirtek might be able to repair it...cheaper than a new pipe anyway.
Mounty
PostPosted: Thu Aug 16, 2012 1:12 am Up
Might take you up on that BSI, any idea how much? Are they an easy fit?
Pirtek, thought they only did rubber hoses? Maybe not
Mounty
PostPosted: Thu Aug 16, 2012 1:20 am Up
Sorry, I meant LeeThr re the pipes for sale. Wink
PostPosted: Thu Aug 16, 2012 3:18 am Up
Nope, along with many other types of hose / pipework stuff they do for industrial applications they also do power steering & aircon pipes for automotive stuff Wink
Just give them a pattern to copy & they can make it up for you.
I got my Goodridge brake hoses from Pirtek ( there a Goodridge agent ) as I used the work discount Laughing
