Online Now [320]:
Visitors: 319
Today: 125925
Total: 156232245
Forums › The Car › 206 Problems › Axle mount bushes
Axle mount bushes
Fifer
PostPosted: Sat Aug 18, 2012 12:26 pm Up
Is it possible to change the rear axle mounting bushes. After changing the axle bearings I'm still getting some clumping from the rear. Axle bearings now have no play. I believe the shocks need changing but the upper mounting bushes look in a poor state as well.
If you can change them do you need a press or is it just a simple swop?
1.4hdi 02
PostPosted: Sat Aug 18, 2012 12:45 pm Up
Doubt its the bushes, i;d check the shockers first.
Fifer
PostPosted: Sat Aug 18, 2012 1:04 pm Up
Just took the spare wheel off and crawled under. I then bounced the car. I could hear the pfffft on one shock but the other was silent. Guess that it then. New shocks needed.
1.4hdi 02
Fifer
PostPosted: Sat Aug 18, 2012 1:46 pm Up
1.4hdi 02
usher
PostPosted: Sun Aug 19, 2012 12:19 am Up
bushes can be a pain but should out live the car, they push in and out, but can be difficult seabrook did his on his spare axel
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
Fifer
PostPosted: Wed Aug 22, 2012 5:07 am Up
Removed the shocks and they seem gubbed. I can push them to any point and they just stay where I left them.
1.4hdi 02
usher
PostPosted: Wed Aug 22, 2012 12:04 pm Up
thats oil filled shocks
project thread WIP
garage
FAQ
206 gti firedance
Fifer
PostPosted: Wed Aug 22, 2012 12:25 pm Up
onSo are they supposed to do that. Oh well I think they needed doing anyway. I'm just under 100, 000 miles so unless previous owner did them. Got both for £40.
With the shocks off I again bounced the car. I heard a clumping and traced it to 1 exhaust mount. Moving the exhaust by hand didn't give a noise but moving the car did. One hole on 1 Mcount is elongated. Giving a clump. Either way I hope new mounts and new shocks solve it.
1.4hdi 02
PostPosted: Wed Aug 22, 2012 12:30 pm Up
Remember that new OIL filled dampers need to be primed correctly before fitment on the car Wink
You cant just bolt then straight on from the box.
Fifer
PostPosted: Wed Aug 22, 2012 12:56 pm Up
Oh good god. Today is defiantly a school day. I am learning to hate this suspension set up.
How do you prime the shocks?
1.4hdi 02
PostPosted: Wed Aug 22, 2012 1:18 pm Up
Wait till you have the replacement ones first.
Oil dampers need priming where as gas dampers dont.
bradski
PostPosted: Wed Aug 22, 2012 1:37 pm Up
hi i just fitted new shocks and just bunged em on do i need to take them off and prime them if so how because ive still got a lot of axle tramp thanks in anticipation bradski
new to 206 ownership so could ask dumb questions at any time thanks for your patience
