Latest: heikkisj
Overall: 17126
Online Now [44]:
Visitors: 43
Today: 14095
Total: 100228480
Forums › The Car › 206 Problems › oops! broke the alrm switch near the handbrake
Rich_T
PostPosted: Sun Aug 19, 2012 5:14 am Up
Had a minor issue with the handbrake console ( somehow managed to drop something in the gap) which meant that in order to retreive this item i needed to take the plastic cover off.
In doing so i forgot about the wire that goes to the alarm activation switch, and as a result the switch is now broken and irreparable Embarassed
Does anyone know a source for these switches its the one with the wifi/alarm symbol on - thanks.
ukskater01
PostPosted: Sun Aug 19, 2012 5:24 am Up
What's actually happened to the switch? Has the wire snapped? I'm sure you could get one from Peugeot or ebay
Rich_T
PostPosted: Sun Aug 19, 2012 6:52 am Up
Thnaks for the reply, the wire is OK, the plug on the end of the wire is OK.
what happened is the plug didnt come off the switch so the bottom part of the switch ( with the plug attached) separated from the upper part of the switch, leaving the internal circuit board in the switch exposed, complete with now broken contacts.
does anyone know where to obtain this switch, and/or what the part is called? ive tried google, etc but all that i can find are question as to what it does - disables/enables the internal sensors
ukskater01
PostPosted: Sun Aug 19, 2012 7:00 am Up
Just had a look online too, think Peugeot is your best bet
PostPosted: Sun Aug 19, 2012 8:36 am Up
Pm harry, hes bound to have a few of these knocking around.
