Online Now [477]:
Visitors: 476
Today: 155454
Total: 156507441
Forums › The Car › 206 Problems › Braking help!
Braking help!
deebee
PostPosted: Sun Aug 19, 2012 10:21 am Up
My 206 new problem, i drove braked and no brakes looked and found no brake fluid, can i now put more brake fluid in after i braked few times without some in? If not what do i do?
Breaking 2.0 hdi with ps and gti bits
ukskater01
PostPosted: Sun Aug 19, 2012 10:25 am Up
You need to get it to a mechanic, there must be a leak somewhere that needs fixing first
PostPosted: Sun Aug 19, 2012 10:26 am Up
First of all, you need to find out why there is no brake fluid.
If no leaks and it's just through neglect, which is very unlikely, then you can add new fluid and bleed the system through to remove all the air.
deebee
PostPosted: Sun Aug 19, 2012 10:33 am Up
there's a slight leak where its joins by the rear axle, but it looks like it can be tightened... So if i send it to garaged how much you recon it will be? My brother seems to think the servo or summat will be broke i can see a clear leak where its been leakin on the road
