Online Now [534]:
Visitors: 534
Today: 177916
Total: 154192912
Forums › The Car › 206 Problems › Axle stub pins - anyone changed them
Fifer
PostPosted: Thu Aug 23, 2012 10:06 am Up
Has anyone changed the stub pins fitted to the axle? IM axle state on their website they charge 20 per pin if the axle is off the car. Now this seems cheap to me and also means it must be able to be done. I would imagine they are pressed in so how would they be pulled out again?
1.4hdi 02
PostPosted: Thu Aug 23, 2012 11:20 am Up
press out or hammer it out
PostPosted: Thu Aug 23, 2012 11:30 am Up
Press is the professional way Laughing
Fifer
PostPosted: Thu Aug 23, 2012 11:54 am Up
I take it the press would need to run through the pin on one side and through The axle to pop out the first pin. That would be a good sized press. Having had no end of trouble just trying to free the torsion bars I can imagine the pins would be a nightmare to try and hammer out. Again you would have to go through the axle I believe. Looks like I might just have to save up for a refurb. If I knew where to get pins from and that they would give I would give a try.
1.4hdi 02
PostPosted: Thu Aug 23, 2012 12:39 pm Up
dealer no longer supply the pin individually.
they come with the arm
